- Apr 13, 2009
- '06, '11
- 3.0 V6
I can definitely see a use for that, especially an enclosed work trailer. The insurance might come down enough to pay for monitoring costs too.
So I saw mention of using eye bolts for tie downs and I would strongly recommend against this if you’re intending to use hardware store eye bolts, they aren’t truly load rated. Rated eye bolts are more expensive, and I never much liked eyes sticking out potentially in the way. Much better to use D-rings for tie-downs, they lay flat when not in use, TSC and other places have them, and they are load rated. I bought some 3/8” weld on rings and there is 7 welded on the little trailer, three across the front, one on each side in the middle, one in each back corner, and I welded nuts in place to bolt one in the center of the rear (that way a mower deck doesn’t have anything to catch on but the ring can be bolted I place quickly if needed). I also put stake pockets around the edge and with the way the C channel frame is, I can hook there too.
Are load rated eyes forged or something? And hardware store eyes cast?
Yes. Load rated eyes are forged. Their load rating is much, much higher than cheap bent rod eyes. But they still must be used properly to retain the ratings.Are load rated eyes forged or something? And hardware store eyes cast?
I did something like that in the 70s, but we had to dig into the dash and find the wires they all had to hook to, It was a large rental/lease outfit, when I started had about 1200 tractor trailer rigs and I think 800 of them were getting the trip masters was what those were called. It told what speed they drove, what RPMs they shifted, all kinds of simple stuff, and that was high tech then. In fact a number of drivers quit first.Some of our work trucks have a similar device that plugs in the ODB2 port. Cheap to buy around $50, but are $400 a month to monitor.
Tells you where they are. How fast they drive, even when the truck is running.
