- Feb 8, 2022
- Saint Paul, MN
This little idea isn't for everyone, but it works well for me. i don't go off road, try to ford raging rivers, or climb over rocks. I do need to use a winch every once in a while, maybe once or twice every couple of years. The situation is always the same. I pull someone who is stuck in the snow, on more or less level ground. Or maybe even, I have to pull myself loose. A new off road bumper with a heavy duty winch would be overkill.
I chose to install a hidden winch instead. The one I chose was rated at 4,700 lbs, more than enough for my purposes. My Ranger reg cab weighs in at 3,000. I mounted it just behind the front valance, bolted a 4'' wide chunk of steel to the frame just in front of the radiator. I reinforced the valance just behind the fairlead. and bingo, everything came together.
Actually I've used it twice already. Works like a champ.
