Tractors
They're all over Amazon and Ebay like THIS ONE, it's the current thing in hydraulic stuff I think instead of regular pipe threads... it's basically just O ring boss standard threads... or at least that's what I was thinking but also why I haven't ordered yet... gotta do some more looking before I jump in.
I'll have to do some more looking, the pictures show the SAE O ring boss versions but they are BSP which is dumb, I'll have to look into it, might keep the two lever setup I'm used to at this point...
Can you just reseal it?
Baum Hydraulic out of Omaha was my go to when I dealt in tractor parts. Super knowledgeable people. They might have kits to reseal what you have. Valves, cylinders, motors, cylinders and seals for everything they are an awesome place.
Also where I got the bronze bushings for my tcase shifters and o rings for my D35 lockouts too lol.
Yeah, after what dad went through with his tractor last week, if I ever get one I think I'll have to go with something older like what you started with.
He's been around tractors and stuff for years, used to work on that kind of stuff professionally. The first one he owned was a used Yanmar 2000 that he bought maybe 20 years ago. Worked good but he wanted something more capable with 4WD and front end loader. Bought a brand new LS XR3032 about 5 years ago (guessing there) and it did good until last week. Only around 200-250 hours ont he tractor and the emissions air pump burned up. $2000 replacement part. Way it's integfrated into the electronics it can't be bypassed. Since I really only need a bush hog deck I might just have to get his old Yanmar that he hasn't used since replacing it and be happy.
We went thru the trans on one (marketed as a Montana) of those once... and only once.
10 years ago they had given up on the US market and stuff shipped via slow leaky boat from Korea as ordered. Everything was at least a month out.
Manuals were translated by a computer from Korean to something else to English it seemed. It was like rockcrawling with your mind to read them. Absolutely horrible all around... and thus anything LS was banned from the shop.
Our theory on the trans was the shift linkage was so wimpy/flexible it effected how well it went into gear and thus it burned syncros.
Might be better nowadays, I think now they make the little guys for New Holland and I don't think CNH would tolerate that BS.
My stupid old tractor has been good to me, I've had some issues here and there but nothing has really cost me money, just time so far. It really needs glow plugs which are not common, I should order some once I find the link of the ONE place I could find them... next month, I've hurt the credit card enough for a couple weeks...
The janky old valve is a no name from the '80's, I'm pretty sure I could reseal it but the bores for the spools are likely shot, it's nothing special... I'll take an inventory of the type of fittings that's on it right now but I think everything is NPT... I did some looking and didn't see any 2 spool with NPT fittings but there is a 3 spool which would open up to a hydraulic top link or a remote for something (or grapple...) for like $76 shipped straight from Vevor... we shall see... options...
Just realized I took a pic of my old janky valve a few years ago the first time I was thinking of looking for a replacement... also a pic of the JANKY external pump mount on the side of the engine... I've mildly reworked it a little over the years, one of these times I'll add a flat idler to get some more belt wrap somewhere since it slips, that's my current over pressure relief...
Thats a lot of N-series there! mostly ‘8’s.
Those tractors were sitting in the same place two years ago. I believe they're yard art.
Mounted my new front tractor tires the other night, I even aired them up further than I trusted the old tires, up to 43psi like the sticker on the wheels state, I think the new tires are marked higher but whatever... narrow tires with innertubes suck to mount, really hard to get the valve stem though the hole...
Tonight I decided to move the boom truck in the back 40 so I can get access to the last gopher that's out there... tried backing into the front bumper in low range, barely did anything, tried backing into the rear bumper, same, tried pushing from the back bumper and nothing so last point before giving up was chain around a frame rail and forward, it worked but barely (pulled the front tires off the ground). Annoyingly when I went to put it back in park I found the hornets nest, it's in the drivers door apparently... but luckily it's under 70F so they're slow...
Next step was mowing under where the boom truck was with the riding mower before dark...
And the question you're likely asking is what the heck boom truck does your cheap ass have? It's my brothers found off a friend of mine for cheap but it's an '80 F Super Duty I think with a 400, the generator that runs the boom is froze currently and from what I hear the C6 only has reverse... but $500 is still cheap no matter what... it's on "the list"...
So apparently I am now the owner of a Ford Ferguson tractor…
Perhaps I shouldn’t be allowed auctions…
