Thanks. Currently the wheels I'm looking at are Pro Comp 51 series 15x10 with a back space of 3.75 and an offset of -44.You're gonna get a few different answers here. For whatever reason... these trucks all seem like they vary a bit and what works on one doesn't work the same on another. Something else to consider is wheel width and backspacing... too wide or less backspace will cause clearance issues.
On my truck... I run 265/75/16's on 16x8 inch wheels with 4 inch backspace at factory ride height with no rub.
View attachment 83787View attachment 83788
do you think that is to wide?That's pretty wide and less backspace then factory. Those are basically the wheels I was talking about above.
Currently a 32/11.5r15 BFG AT KO2. I've seen some people claiming to fit that size on same spec wheels as the ones I'm looking at with only a mild T-bar crank.Personally... yes.
I mean... what tire are you looking at.
Ok thanks for the infoI had Procomp 33/11.5-15 MT tires on stock Alcoa wheels on my Ranger with just a 1.5" T-bar lift. They would rub occasionally with some flexing. I now have 33/10.5-15 AT tires on the same wheels and they rarely rub and only very slightly when they do. It takes some extreme flexing to get it to do it. I like the 33" tires much better because I get more ground clearance and have much less rubbing. Most people want wider tires, but I like the 10.5" wide tires. I feel in better control off road for some reason and visually they look fine to me.
