Can a 4.6 fit in a 1987 ramger
Tucson, Arizona
First off, the 4.6 us free, coming out of a 2001 mustang from my father, only has 22k miles on it and is coming with computer/ tranny/ rear end. He's coyote swapping his. Can that motor fit inside my 87 ranger?
I'm hoping nothing needs to he changed to the frame or the cab? Thanks for the replies.
It can fit, but not easily. The 4.6 is crazy wide compared to most motors people want to swap in.
People have done wierder / more difficult swaps in things just because 'it was all there'..
I say go for it!
I think the engine it is too wide to fit in your Ranger, can you find pictures of one already installed in a 1st generation?
But, if I did the swap I would go with a carb set up. If going stock, you are going to need a programmer, imho, if you plan on getting this off the ground without going broke going to a dealership or speed shop. That plus a 3" body lift and doing something with your steering. I am pretty sure the 4.6 heads will go right where your steering shaft is. Clearance on the heater box is doubtful. Are you removing the whole harness from the Mustang?
A 2001 Mustang is more complicated then a 1998 Mustang.
What about the exhaust and the cats?
What about the fuel tank, the fuel pump, and lines?
What about the speedometer head unit ??????
What about the vapor canister and check valve/sensor for the gas cap on the filler neck? (which I believe is on the 2001 Mustang).
PATS?
Summit no longer carries this:
Edelbrock VICTOR JR MANIFO Part 2839
$1247.99
I see this "free" engine being $2500 just in additional parts, not counting the labor, if it fits, along with the transmission. You are going to do some welding and fabbing to use the transmission (AT or MT) and rear axle. Not to mention the driveshaft.
Anything is possible with enough $ and time when it comes to sticking an engine into a vehicle.
For $2500 and 100 hours, I would buy a beat 1990-1994 4.0L 4x4 Explorer, buy a reman engine with 3 year warranty, and swap that deal in. Or buy a low mileage Explorer with a blown tranny, swap the drive train and put in a rebuilt transmission. That way you get a better rear axle, a good front axle if 4x4, some extra rims (hopefully alloy), maybe some better buckets. The Explorer swap would probably be 30-40 hours.
DO IT. Forget what the "ney sayers" say. If you have the "free" stuff AND the Ranger, don't let the "easy" stuff get you. People have put big blocks into small trucks before. Yes the 4.6 is wide, but with proper planning and some good fabrication, it can be done. and probably SHOULD be done just to stop all the " it can'tr be done" talk. I thought about putting a 4.6 in my "01 Ranger too. Had everything I needed, except the shop space, so I got rid of the 97 Lincoln Continental donor for a '00 awd Explorer Donor.
It can be done.
It has been done in a Ranger before (though I wouldn't swear to a TTB Ranger).
There are FAR better options.
Of course there are, but he already has it, and it was free.
Sigh...
If you know something about the topic, then by all means - contribute.
If you're jumping in to send someone down a very expensive and painful rabbit hole, consider the implications of giving bad advice.
This is a 4.6 next to a 302. This is the primary reason it's a bad swap candidate.
A measly 2v 4.6 is wider than a 460...
Doable though.
Delete the HVAC. Might get something aftermarket to work that is self contained in the dash.
Re-engineer the steering, outside of frame, maybe new suspension with a rack.
Lotsa work for 220hp.
They fit a lot better in the 98+ trucks but are still very snug.
I'm not sending anyone anywhere. I'm saying do what he wants to do and to not let negative Nancy's stop him. He can do his own research of whether or not he wants to attempt the swap. A guy put a twin turbo 7.3 Powerstroke into a Ranger that he also turned into a dually, so anything CAN be done. I don't know how much $$ OP has or his skill level. Do you?
The only way I'd even consider encouraging him would be to know EXACTLY what his skill level is. That's the whole point.
anything is possible with a welder and some patience.
