- Jul 31, 2021
- NW Florida
- 2.3 (4 Cylinder)
- Total Drop
- 1.5” till I get these springs replaced
- Tire Size
- 225-70-R14
My Ram needs an extra fan on the condenser. I'd ask this on a Ram forum, but TRS is byfar the most active and knoledgable automotive forum I've come across.
I could wire the solenoid to the compressor, but that would just mean it's on all the time. I want to be able to turn it off at highway speed or whenever else I decide. I'm sure there's a "proper" way involving differentiating pressures, temps, and probably controlled by a simple computer, but that's just too much and I shan't be drilling into any AC lines. Best I can figure is to have a switch on switched power in the cabin to control it manually. Now the problem is I'll have an extra 10+ amp load during startup if I forget to turn it off, and starter noise would probably be bad for the fan motor. Is there a way to have an on/off switch that reverts to off when power is disconnected? I found this schematic either here or a Camaro forum for separate, momentary on and off buttons that would work, but I'd like to only have one button. Maybe a (terminology lacking here) 3-position switch that is spring loaded to the middle, NO up, and NC down, preferably lighted if activated? I bet that exists, I'll look around.
Also... Where does switched power even come from? Can a switched power circuit be overloaded? Should I have the fan run from a non-switched circuit? See any problems with my schematics below?
