2.3L ('83-'97) '93 2.3 crank wobble okay or not?
genhawk21
New Mexico
Hello -- just completed a timing job on a 1993 2.3l and there's a slight wobble to the crank pulley. I'm not sure whether it was like that before or not, and not sure whether this is an issue or within the normal range. It's running great otherwise. Didn't notice any issues in seating and torqueing the crank bolt or harmonic balancer. Thanks! Videos here: ,
Take the belt back off and then grab the pulley and try to wiggle it. If it has play, then find out where it's coming from. If it's tight, don't worry about it.
I've seen way wobblier.
All tight and even torqued to spec - going to stop worrying about it, thanks!
