- Aug 6, 2007
- State - Country
- GA - USA
- Vehicle
- Ford Ranger
- Total Drop
- few inches
- Tire Size
- ~30"
Since I bought the 85 long bed yesterday, I'm at an impasse on how to build my truck. I've got to decide on long bed vs short bed for my build and I don't have enough experience to make it an easy decision. Thanks to the previous attempt at this project with an 86 regular cab short bed, I have nearly everything that I would need to build the truck either way.
Option 1: 1985 Ranger Regular Cab, Short Bed
Option 2: 1985 Ranger Regular Cab, Long Bed
Here's the jist of the potential builds going off memory of the parts I have on hand.
89-97 DJM Beams
95-97 Ranger Spindles
All poly bushings
1.25" front sway bar
Explorer 8.8" 3.73 LS, installed spring under with anti-wrap bars
1" BII rear sway bar
Explorer 5.0L w/ 4R70W
Main difference between the two builds would be the extra length and gas tank. The short bed would get a BII tank (or other) behind the axle, while the long bed is a dual tank and will stay that way.
Its going to primarily be a driver and cruiser so comfort and ride are important, but want to have decent performance and handling too. My 84 was a long bed and at stock height, with the front sway bar and 16" wheels, I was pretty happy with the ride and didn't hate the handling. Can't remember if I did poly or rubber bushings on it. I'm pretty sure new poly bushings, rear sway bar, lowering, and better shocks would have made it even better. Before buying the 85 for its cab yesterday, I was planning to build a short bed thinking it would be better handling and more sporty. The other side of the equation is that this whole build started as a tribute to what the 84 was and would have been, it was a long bed with no plans to turn it into a short bed.
I've never driven a SWB Ranger thought and don't know how differnt the driving exterience is between the long bed and SWB trucks in stock form. I also finally looked at the dimensional differences between the two and noticed that there is only a 6" difference in wheel base and 12" difference in overall length. Now I'm questioning if that is really enough to make a noticable difference.
Have you dirven both? How did they compare? Am I overthinking this? Just shut and build the long bed since it's a complete truck?
89-97 DJM Beams
All poly bushings
