you can still get into photobucket but they won't let you download the pics, or link them anywhere without paying for an account.
i hadn't used it in 10 or so years too but they sent me an email saying i need to log in to keep my photos from being deleted, about 3 weeks ago. i did and they were all still on there but not useable without a paying membership
Check for a vacuum leak, I don’t remember details of your truck but I had a 93 4.0 that did that, ended up being the fuel rail gasket. It had pulled in at the front & rear. I had pictures but they are on photobucket and its been so ling since I quit using them Im not sure they exist or how to access them now. I probably discussed it all here but its been many years ago (10-ish?)
It's holding the idle up to the speed the engine was at before I released the clutch. It doesn't go down until I come to a stop. However, if I'm going slow the idle sometimes goes up when I release the clutch before going back down again. I'm sure it is something from the throttle body to the air filter box. Those are the only things I did anything with. Anway, I cleaned the MAF sensor and the clip that locks the connector turned into plastic powder when I touched it. That's what hot summers do to plastic and rubber parts. It made me start wondering if coating plastic connectors and rubber parts with something like Sil-Glyde would work as a preservative. I have the connector held on with a zip tie. I may make a trip the the local pull it yourself boneyard and get a connector there, if I can find one in good shape. Application cross references state the same connector is used on many Ford an Mazda vehicles after about 2000. If that fails, Rockauto has them.
I ordered a cheap bluetooth OBD2 scanner. It probably has cloned ELM327 chip, but it will do what I need it to do right now. When I get the time I'll do some research and try to find one with a real ELM327 if the one I ordered has some shortcomings.
Hauled a floor jack and toolbox up to my friends house to change the oil in his Honda Odyssey. His wife put about 10 quarts of oil in it because it has a small oil leak.
She genuinely thought an engine could never have too much oil. I explained the engine mechanics to them, but he is an actual philosopher (PhD in philosophy), so I’m not sure if my explanation was taken as theoretical or practical. 😂
I pray that they take these life lessons to heart and realize the importance of taking better care of their autos.
Put a on/in a new used ECM, intake tube, alternator and repinned the oil pressure sensor wire to work. She’s running like a factory vehicle now. I’m also going to install a new T-stat today because the new one that’s in it is sticking, causing the temp to get up to 210 deg which reads as too hot on the gauge.
IAC might be stuck.
IAC might be stuck.
The IAC is doing what it is told to do. If there is a vacuum leak the IAC will attempt to compensate by closing and reducing air flow. If the vacuum leak is large enough the IAC will not be able to bring the idle down to the specified range, a code will appear stating the IAC is unable to compensate. If a sensor is sending the incorrect data the PCM which then tells the IAC to do something, such as allow more air into the engine to help compensate for a rich mixture due to the MAF or the TPS sending data stating the volume of air or the throttle is operating at a greater value than it should be. The idle also goes down to normal at a complete stop which is due to the speed sensor indicating I'm not moving and the PCM sending that data to the IAC.
Removed the redneck 2x4 “tailgate.” Rattle canned the factory tailgate flat black. Ace spray paint actually lays down fantastically. I think I like it better than Rusto. Only time will tell if it’s any good. Purchased a 2” lowering block kit at Advanced. Hope to get it installed this evening. Old U-boats are looking pretty rusty. Might even hang out underneath to do some rust treatments.
I was just going to mention the speed sensor as I've heard of others with that solving things... if there's a bit of goo on the tip it could be noisy... that could be taken wrong, I'm tired, you get what you get :)
Since the problem started immediately after cleaning the throttle body, I'm sure it is something I did and likely not a sensor issue. Unless I the throttle body cleaner did something to the TPS.
I just ordered a Flowmaster FX Muffler for my 93 Ranger 4.0hh. Gonna get ready to Rumble.
I'm stoked. It says it doesn't fit my Ranger, but I have my doubts.
Nothing to the ranger other than drive it here. Was my first time seeing the 4 wides tho. And I must say I'm highly impressed. I tried to upload a small video of 4 wide launch. But it wouldn't take
That looks awesome to watch. I have never heard of four wide
The ranger killed it another Friday night and Saturday. Drove to kingsville with the other cars but they were going to fast, I was bouncing off the governor so I need to take that off somehow. 92 almost got me in trouble at one turn because I couldn't go faster to get out of the way.
And then after all the bike event stuff Saturday morning, I got a super deal on a front load washer and dryer combo, 200 bucks. So we ran to the island and loaded them up. I did not know front loader washers are almost three man lifts though and make the truck squat down. But having all that weight in the back made it ride like a Cadillac
Swapped out my flasher relay for a new one that allows LED’s to function properly instead of the hyper flash. Cleaned my EGR Valve. Debated about deleting it as I was trying to tighten the locking collar nut up against the firewall. Today going to attempt the fuel pump and filler neck hose. Happy Sunday y’all!
superj; Most front loaders have a big mass dampener-the one on mine is concrete…..
-Jazzer
I just used the CB antenna on my Ranger to totally splatter a fluorescent light bulb in the garage when I pulled it to get at my vacuum to clean up F-150A.
Event Coverage
TRS Merch
