I have no voltage to my engine coolent sensor   Im not sure if its a wire problem or ECU?  I think the pin no. is 38 but is that looking at the ECU or the Plug?
If that's the signal return, it could be less. The reference is 5 volts and the sender drops part of it. That 2.7volts is what the ecu interprets as "x degrees". So, depending on the temperature, you could get a return anywhere between 0 and 5 volts or some range within those values depending on how the circuit is designed inside the ecu.Up date, at pin no, 38 I have 2.7 volts I thought it was 5v ?
Ok Thanks Eric, im getting somewhere , so I see the coolant sensor and others are all connected to a Gray/Red wire, is that a ground? what do I test it to? Volts or ohms?
Also after I replaced the heads my temp gauge isn't working? could I have pinched these wires somewhere along with the coolent sensor wires ?
Got anywhere with this?Part 1 fixed, all sensors are good and working, problem--- stuck open thermostat. motor never got out of short term fuel trim.
Now time to see what's going on using the iPad fuel trims, O2sensors, injectors, etc.
