Floaty steering at high speed
The wander is likely lack of caster....
But. .define wander...
I can drive my truck triple digit speeds comfortably with one hand....back when it was Gasoline powered....
but even today it's fine at 85 travelling to Florida and back....
For me
One time one of my crew was travelling with me home.....and he made it about 3 miles before pulling off the road... shaking ....
Young guy about 20 or so and had never really driven anything other then a front drive car... I barely made it to the next rest stop to take a nap ...
So ..it's all relative.
For me
It doesnt wander all too much. Its not like I am drifting into another lane or anything. It just doesnt feel glued to the road. I guess a slight drift is a better explanation.
I was referring to shran....he and I have straight axle junk now.....
I am thinking your truck is what I called normal for ttb. Those tires look burly for 33,s....might just be the pic....but burly will track every imperfection in the road ..
They are beyond burly...I think your assessment might be correct. They are killer offroad though! I am gonna run it like it is right now, and I will update this thread if I make any changes to the caster or tires. Good info for futre B2 idiots like myself
Your definition may be different than mine but it will track straight for a while and slowly drift towards one side of the road, then when you go to correct it is very easy to go too far and make it dive towards the other ditch... Then back to the other side when you correct again. Once you get used to it, it's really not a big deal.
I don't have an easy way to correct caster. I have a 78/79 D44, full size bronco radius arm drop brackets and 0 degree C bushings. I tried the degreed caster correction C bushings but I can blow them out in one wheeling trip, the rubber ones from NAPA are the only ones I can keep alive for any length of time.
I'll GUESS it's the tires, too much air from looking at the picture (sidewall and dirt pattern) or just that tread pattern.
Is it just me or the picture the joint in the drag link looks like link itself is pitched drastically forward. Didn't know if it was rolled during alignment causing angle change as suspension droops/compresses. Had any one follow you see if it appears whole truck wandering or body only? Determine if it's tires or suspension. GoPro on the steering components may help out as well. Turn it on, go drive, come home, open beer and watch 😆
Also had an 88 full size on 38 boggers that showed a lot of flex/movement between frame rails when steering could watch driver side load up and move.. spare piece of round stock plated between the rails stiffened that up drastically. I would like to think the Duff bumper will aid in rigidity kinda my thought with my Affordable one. If tires are as equally in question since I'm sure they were installed in conjunction, have some stock stuff lying around or you can borrow and that's a pretty quick check. Alignment will be slightly different but treat patterns can affect a lot and those tires are almost an S shape which to me would probably hunt for even traction. They are not directional/inner outer correct?
