lil_Blue_Ford
Cut & Weld
⭐Supporting Member
💻 TRS Socials
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Total Drop
- 4”
So I have done some searching but I still feel like results are inconclusive.
What I’m working on right now is my 92 Ranger with factory AC. Naturally it had R-12 originally. Don’t believe it was ever converted to R-134a since there was not the common fitting on the accumulator. Some previous owner removed the pump and cut the suction line out. I stripped out everything but the evaporator and used the good pump from my 00 with the rest new. Vacuumed it down after getting it together but haven’t filled it yet, partly because I’m not sure about if I should change the orifice tube or not. Bear with me, I did pull the orifice tube that was in there and I believe it to be brown in color. Local parts store wanted like $20 for a new one (not sure what color). I had the bright idea of ordering a variable one online that said it fits.
Thats about where things started to go off the planned course. I had everything set up and was going for it. I put the orifice tube in and the liquid line wouldn’t fit over. After some work at it I finally determined that there are little plastic nubs on the orifice tube and the ones on the variable one were in a different spot. Pretty sure it would fit if I trimmed those off, but I wasn’t sure if that might cause a potential problem. So I rummaged around in my spare parts and came up with a brand new blue one that I picked up somewhere and forgot about. It matched the size and shape of the one that came out of the truck. Not really considering that colors could mean much, it went in. Now that I discovered color does matter, I’m wondering if I need to make a change or not. One thing I read said to stay with the same color and another said that blue is the typical color for Fords that got converted from R-12.
So… what say ye?
So… what say ye?
