Hello all,
Not sure if this is the right thread to post in so if it is wrong, sorry.
I've been thinking and researching about what I need to do to fix the speedometer so that it reads right after a tire and/or gear change. I've seen that you don't need to change anything to correct the speedo if you only do a gear change. That doesn't seem right though in my mind. I read about a transmission speedo gear that can be changed out and also just an electronic fix as well. I'm not sure which one applies to my truck though.
I also am not sure what needs to be done with my 2011 Ford Ranger XLT 4x4 5-speed manual to fix the speedo after I do the tire upgrade and gear change. I believe I have 3.73 gears now and I will be going to 4.56. I have approx. 29" tires and will be going up to 33" tires after I have the gears changed.
Can anyone tell me what I need to do and confirm what the right thing to do is to correctly calibrate the speedo for the new tire size and gears?
Thanks in advance.
Thanks in advance.
