- Feb 11, 2021
- Seattle, WA
- 3.0 V6
- My credo
- Keep your mind like an umbrella, it only works if its open... Continually learning.
Tire size effects this as well, the larger the tires you use the higher "numerical" ratio you need to compensate.
If you run large off-road tires you even want to consider 4.56 to 5.13
My Nissan came stock with 4.63 gears and 235/75R15s, when I SAS'd it I went with 5.13s on 35 which brought me back close to the stock gearing.
