So I am currently trying to add factory fogs into the truck. Yes, I have searched. I've got the switch wiring behind the dash and the switch.
I'm aware I will need to add relays. My issue is where do the fog harneesses connect? I see a 4 pin connector on the driver/passenger size frame area, next to what I believe is ABS/wheel speed connector or vac lines for hubes. Round with two tangs. Where do your factory fog jumper harnesses connect to?
