project red ranger
This is where things get a little scary...
O now I see the rust spot they were talking about. Or If I put a mirror her I could pick my nose.
Sorry I had to the build is looking good.
that looks so fermilliar for some reason, where is it at
Update!
PROGRESS HAS BEEN MADE!
:icon_hornsup: :icon_hornsup: :icon_hornsup: :icon_hornsup: :icon_hornsup: :icon_hornsup: :icon_hornsup: :icon_hornsup: :icon_hornsup: :icon_hornsup: :icon_hornsup:
BTW, I like the rocker icon!
hmmmm are you going to mold the body around the frame? and cut the front frame horns off???ans what size tire you going to run?
Honestly... I'm really scratching my head right now.... best a luck to ya!
hey, if you and piney power wanna wheel the last weekend in august(the 31st,sunday)
im going down i think to the pines to run hidden lakes mabe and whatron, if youd like to join that would be great
that is if you have a street legal rig....
This is the reason the body is so far off the frame.
Eventually Yes, I will cut the frame. I had to extend it for the spring hangers, body mounts, bumper etc. it's alot easier to cut off excess rather than try to add more.
As for tires, they'll be 23.1-26 for those of you not familiar with tractor tires, about 64x23x26
Are not covering the motor when you're not working on it? I'd hate to see your work get trashed by a lil water and some rust. I like the birdcatcher, by the way! :icon_hornsup::icon_hornsup::icon_hornsup:
Damn that's huge. Can't wait to see the finalization. This is a visual for everyone:
Hm. Good luck with the next phase of this build.
Pete
Unfortunatly, I don't have a garage big enough for this beast. I really wish I did! As far as the rust goes, When I broke in the cam I didn't realize the linkage for the two carbs was not adjusted properly. This made my front four cylinders run lean causing the front four pipes to get too hot and burn the high temp paint off of my headers. Now I gotta sand em down and paint again. I'm very proud of my headers, my first set I ever made, What do you all think?
Those skidder tires probably weigh a ton! I would guess them to be 14ply and weigh about 600ibs a piece WITHOUT rim. Mine are 6ply ag tires, about 300 each without rim. I like the chains, might have to get me some of those!
