Am I getting had by alignment shop?
So am I. But because they didn't call.
Your post was clear.
Your invoice even more clear.
Contingency as stated in your post is fair. One hour and fifteen minutes per side for bushings on a truck you could not get the pitman arm off of is extremely fair.
If it was an easy job. You would have got it with your puller.
I'm apparently not making this part clear, my[friend's] puller tool is defective, a damaged HF unit. i had to dislodge a socket he had gotten stuck on the screw before even starting that bit. i.e., it was used and abused.
but i digress.
i should have checked out the bushings beforehand. the reason I purchased and brought them to the shop was reading [a few] posts about the potential of needing them, and the concept was just "bring 'em with" so I assumed(again) that it wasnt a big deal
but i digress.
i should have checked out the bushings before hand. the reason i purchased and brought them to the shop was reading [a few] posts about the potential of needing them, and the concept was just "bring 'em with" so I assumed(again) that it wasnt a big deal
Aye. You are right to be pissed.
The fact you paid over 25 percent tells me all I need to know about your character. Your a straight up human.
They can offer something for not clarifying over 20 percent differential of labor before doing it. No excuses for that.
I am sure if they would gave you the range. ..that I would have...which is 1/2 a day..at least you could have had the option to get it all out if the way on your time..
Haha while I appreciate the compliment, I'm also just strongly averse to unnecessary conflict. Dollars are dollars and I'm no rich man, but after asking the guy where the extra dollars came in and getting the immediate push back of "it's a time consuming process" (with a bit of tone), I'd pick a different battle. As mentioned I'm not a fan of the dead spot, I have to work the wheel a few degrees back and forth to keep it in the lane at highway speeds, but if it's a good alignment, it is what it is
Yes, there is an adjustment on the Ranger steering box
Has a lock nut and a "bolt"
You loosen the lock nut and hold it in place, then screw in the "bolt" to reduce the play in steering shaft movement
Its a trial and error setting, and it could be steering box is just worn out
Best method is to jack up front wheels by A-frames so weight of vehicle is still on them
Then adjust, and turn wheels lock to lock to make sure there is no binding
You don't want to get stuck steering left or right out on the road, lol
OK. Hi guys
+1 on 'failure to communicate'.
+1 on the delicacy, care & expertise needed to fit the pitman arm properly being more than expected.
Could a new employee have bleated the $125 estimate at you unknowingly?
Are test drives done to settle in new parts? That'd add to the total, no?
ps, I know test drives are such a PIA shops don't do 'em but someone said this was a good shop.
Colossal tires were installed at this time, right? Was the OP perhaps startled by the feeling of being in the crow's nest of the Mayflower during a hurricane? Taller rubber will do that.
OK. Hi guys
125 is their flat fee for alignment
There would not reasonably be a fee for a test drive
Someone knows their race team and likes them. I've actually contacted them for work on another vehicle before and twice they didn't get back to me so I went elsewhere. I've talked to other people who weren't thrilled, but there were no horror stories, and since this is an alignment on a vehicle in their specialty wheelhouse, I went there instead of the more reputable non-off-road alignment shop in town.
I have 31s, and I'm quite accustomed to large tires in general, if not on specifically this type of suspension. There is a big wedge of slop in the center of my steering. I've been driving it even more since the work, it is not okay as it is.
Do you have the specs sheet?
forgot to ask them for one when I picked up the truck, they didnt offer (even when I asked about the cost).
I sent them a message first thing Tuesday morning asking for the numbers if they still had them, they have yet to respond. might have to go back down to the shop
