1999 Ford Ranger 3.0 Flex Fuel Automatic. 2WD Standard Cab 6 foot bed. 120,000 miles.
Last summer my A/C stopped working and I detected a strange smell coming from the vents. I replaced the evaporator and accumulater after discovering a leak (and plenty of UV dye) in the Evap housing.
I took the system to a shop to evacuate and charge the system up. They told me that the system was holding pressure but that the system was not blowing cold. At the time, I noticed condensation coming from the AC lines on the driver side of the vehicle. I proceeded to take the truck on a interstate roadtrip and found that it was blowing cold when I was cruising on the highway. Since then, I’ve noticed that the system will blow cold at idle on cool morning but blow cool air at idle on warmer mornings. When I drive at a high rate of speed, the AC will blow colder than the temp at idle.
After searching around, I found that the fan clutch might be the culprit. I replaced the fan clutch the other day and the issue persists. The fan clutch was definitely on its way out as the truck is a lot quieter at idle and acceleration.
I’m now not sure where to go, charging up my parts cannon since the truck is on its original compressor. Any help? Bad relay? Bad compressor? Can I try adding more Freon?
