Help OLE WORMY DOG HE NEEDS A NEW PAIR OF SHOES
Tx
I have a 1990 Ford ranger and I was wondering if a 2018jeep renegade rims would fit I know on some if they are factory they won't.but being a renegade is a little jeep the rims might fit ole wormy dog.
According to Google, the answer is "no". 2018 Renegade lug pattern is 5x110mm. Your Ranger lug pattern is 5x4.5" (5x 114.3mm)
if the bolt pattern is a 5 on 4.5" pattern or 5 on 113mm bolt pattern that is a good start... you might have some other considerations like the diameter of the hub especially if your truck is 4wd (does not look like that is the case according to your info under your username)
AJ
Wheels are often round.
And when you do find Jeep wheels with the same bolt pattern, you will nearly always discover that the center bore on the Jeep wheels is smaller than the hub diameter of the Ranger wheels, so they will not work unless you take them to the machine shop and have them bored out.
Usually different offset too.
Depends on your perspective, they look like rectangles to me
But I am often laying under the vehicle and not looking at it standing up from the side
This is because I drink, not because I work on vehicles
My bottles are often round, from my perspective, because they are often lying flat, empty, a sad site indeed
And tires often have a flat spot on the bottom.
