A little advise if you please
take a chance
5+ Year Member
Las Vegas NV
Good afternoon I have a 2004 edge model with a manual trans. I had a valve spring break about a year or more ago. this wreaked all kinds of havok which resulted in replacing the head along with the other obvious parts. The piston, although dented severely, was not broken and therefore not replaced. Fast forwarding to the night before last I suddenly developed a knock that sounded like a lifter or push rod. After removing the valve covers and finding the lifters to all be tight and in place along with getting small strips of metal out of the oil pan and oil filter I have decided to save myself time and am just going to swap the motor. So my question is due to the 3.0's reputation of breakdowns would it be better on time and cost effectiveness to swap out for a 4.0 or even a 5.0? It is my understanding that Doing either of those is about the same amount of work and parts that are required to be changed. (i.e. wiring harness, instrument cluster, motor mount and transmission) If this is wrong info please also let me know that. I need to get my truck back on the road as it is my sole vehicle but I need it to be reliable. I do handyman work.
I sincerely thank you in advance for your time and shared knowledge
Hmm.
This is a what are your actual capabilities depends answer.
If....I were happy with current performance.
Swap out to a good fresh 3.0
The performance leaves me wanting. It doesnt want to get moving and the fuel mileage sucks at an avg of 14 mi/gal. Between my rack and tools I am carrying a lot of weight on a fairly regular basis. This is why I would consider going to the 5.0. I think the mileage would be about the same except that I would have the power and torque to get moving easier. As far as my wrench turning capabilities, im not formally taught or professionally licensed but have been working on cars and housed since I was old enough to swing a hammer. So i would say above average.
If you have OBD II state inspection requirements an engine swap is out. I never encountered a 3.0 with a broken valve spring but saw many in early 2000's 4.0 SOHC engines, none caused catastrophic failures luckily. Before you decide which engine to go with check your rear axle tag. If you have 3.45's for example, a swap to 4.10's will help power and I suspect would help gas mileage because the 3.0 wouldn't be working as hard to haul a loaded truck around. I wouldn't spend the time and money to swap in a 4.0 SOHC, a 5.0 wouldn't be much harder and might be cheaper to do. You'll need a ruggeder transmission and a bigger radiator.
Muh? Why is that.?.?
Legally...if it remains titled as a ranger....you need a 2004 compliant or newer engine in most areas...
There is a ton if technicality there... especially if you have a federal compliance guy.... But custom title can mitigate this.
And for sure gearing is key.
But.
If you want more....the 4.0 cammer is the easy button.. and selling yours and buying a whole truck is the real easy way to go.
I would go to a 2004 or newer gm 5.3 or Dodge hemi if I had to deal with emissions. But a f150 coyote is definitely not a bad deal...just a fat bastard.
I like the ranger for it's size. So building to suit is just that.
I would describe my self as you do...
Save for the inquiry... And would consider a 5.3 4l80 swap a cake walk..
And win
But.
And win
If the OBD II test is done with the Gordon Darby system like NH uses, the VIN on the registration has to match the VIN in the PCM. You could put a complete 2001 Explorer 5.0 with all the emissions equipment intact into a 96 Ranger, which would be an improvement and reduction in emissions, and it wouldn't pass. That's why I started with a 93- it's pre OBD II. We had to start emissions testing because the feds threatened to withhold highway dollars, we didn't choose to do it. Several foreign vehicles will pas with up to 3 fault codes present, that never made sense to me either.
I think NH will remain on my " nice places to visit but don't want to live there" list.
Thank you for all of the responses. Im going to try to find a 3.0 motor and keep it as is so i can get it back on the road. From what I was told today it will be anywhere from a week to 6 weeks before I can even get one here then I still have to transfer the parts and drop it in. This forum has helped and saved me on more than one occasion so thank you.
The Gordon Darby system is the most commonly used one in states with OBD II testing. NH didn't design it or mandate it, that's your federal tax dollars at work.
Live free or die isn't a joke, it's part of a quote from General John Stark after the battle of Bennington, Vt during the Revolutionary War-" Live Free Or Die- there are far worse fates than death." Constitutional carry, no pistol permit required. No sales or income tax. Almost no cities.
I like the motto. It was someone else who mentioned that.
20 years on here, I have only ever heard the bit of the VIN having to match the computer from you in NH.
After working with salesmen for over 4 decades I have realized I can't control what other people don't know.
Just saying, it does not come up on here often... or really at all.
Vin matching to 2004 is not always what it sounds like. Though the walk around on it is what caused issues tuning. You can vin match as long as it readiness matches and passes tests it's fine
In NH...I don't remember the specifics.
Custom title....such as assembled/rebuilt...or Reconstructed...or composite vehicle or similar....depending on where you live....and sometimes exempt titling or new emissions matching can all work...and can be a shit ton of work to wade through. And net an uninsurable vehicle...well...not cheap to insure.
Those are the standard workarounds for the Darby system.
That is what allows an engine swap ...
That is why you don't hear of it being a problem....
Because it is not.
