- May 7, 2018
- North Carolina
- 1987 STX
- 2.9 V6
The canister filter (just after the tank) is not necessary. I got sick of replacing that filter and having problems with the o-ring not sealing, so I got the later model replacement reservoir (with no filter) and haven't had any issues. You could just remove the filter and forget about it.
I'm intersted to know if the later model Rangers that went with a single high pressure pump inside the tank still have the reservoir or not. I would think that it's necessary, but it may have only been installed because of the low pressure pump in the tank.
