Rangers came stock with 1,100, 1,250 or 1,350lbs springs. The 1,750lbs springs that a lot of places sell are a heavier than stock aftermarket part.
And surge brakes DO meet federal requirements.
In a lot of the cases with the youtube videos, if they had loaded the trailer correctly, i.e. 15% or more weight on tongue/drove responsibly, they wouldn't have had issue in 1st place. Just because your truck has so much power you barely notice the trailer, doesn't mean you should drive like it isn't there.
In addition to 12" front brakes, does your Ranger have 10" rear brakes? I think all 4x4s came with 10" rear drums by '00, but this is Ford...
Making sure your Ranger has a sway bar in back makes more difference than heavier springs. There's a part of me that says heavy springs will mask a small problem until it becomes a big one. If you're needing 3,500lb worth of springs in back, for what is in box/tongue weight, you need a bigger truck.
Section 393.48 of the Motor Carrier Safety Regulations allows trailers with Gross Vehicle Weight Ratings (GVWRs) of less than 12,000 lbs., to have surge brakes assuming vehicle-to-trailer GVWR ratios of 1:1.175. i.e. for a Ranger with 5k GVWR, you can't tow a trailer with surge brakes over 5,875lbs GVWR. But that is so far above Ranger's GCWR, that it won't be an issue for you.
Due note, it is trailer GVWR not actual weight, which is why u-haul won't rent their auto hauler with GVWR of 5,290lbs to someone with 2wd Ranger with only 4k GVWR. Trailer exceeds the allowed limits.
Are they as good as electric brakes - hell no. But they work a lot better than electric brakes when wet - i.e boat trailers. And are a lot better than no brakes when using multiple tow vehicles.
I put a 5 wire plug on my Ranger and trailer with surge brakes - plug is basically 4 wire flat with one more outlet. The 5th wire comes from reverse lights and goes to solenoid on the trailer brake line. That way when I back the trailer up, it doesn't have brakes. I happened to like the surge brakes I had on my little enclosed trailer, but I did play with set up until I got it the way I liked it - the shock in hitch being replaced with one that applied brakes appropriate for my trailer's setup. If the shock isn't stiff enough for load/worn out - you get the condition @Dirtman describes of trailer surging forward with braking, then applying brakes hard jerking back where upon it releases brakes and cycle repeats. If it is too stiff, brakes never apply.In a lot of the cases with the youtube videos, if they had loaded the trailer correctly, i.e. 15% or more weight on tongue/drove responsibly, they wouldn't have had issue in 1st place. Just because your truck has so much power you barely notice the trailer, doesn't mean you should drive like it isn't there.
