- Jan 10, 2020
- Las Vegas
- State - Country
- NV - USA
Hi all! You may remember me from my V8-swapped Bronco II last year. If not, visit
www.therangerstation.com
to get up to speed. I've been driving it since the swap. Love the V8 power, hate the lack of overdrive.
-Other than a strange idle fuel mixture problem with the Summit carb (hot soak causes the carb to run extremely lean), it's been perfect. My original plan was to swap in a AOD or 4R70W to get overdrive. I ditched that plan because of the lack of space in the tunnel with the automatic. Between the trans lines, exhaust and trans, it gets pretty tight in there. Plus, I like rowing gears and actually miss the TK5. I prefer the way they work offroad too.
Found the preferred M5R2 out of a 1997 4.2 4x4.
Dimensions for Ford 4x4 transmissions (bellhousing to extension housing):
C6 is 25.75"
AOD is roughly 26.5"
4R70W is roughly 27.5"
M5ODR2 is 27.625"
E4OD is roughly 31.5"
For reference, TK5 is 26.5", a BW1350 is 14" thick vs the NP 208 I'm running is 17" thick.
-This means I'll have to shorten the rear driveshaft roughly 2" and lengthen the front the same amount.
<sigh>
Apparently the auto starter is different than the manual starter.
<sigh>
I'm getting ready to order clutch parts. I want to run the applications over guys who've done this swap. So far I have:
5.0L flywheel, manual starter, clutch and slave from a ~1996 F150
Clutch master from a ~1994-ish Ranger
-How about the clutch line? With my 2" body lift, should I run a line from a Ranger or F150? I would love to run an line, but the slave fitting will be a problem.
-Thank you
Rick's 5.0/C6 swap 1985 BII
I've had my BII on the road for seven years now. It was originally put together with a 2.3L/Weber 32/36 and a TK4 speed. A good writeup is on FordSix, they were gracious enough to allow it in the Orphan Inlines section. https://fordsix.com/viewtopic.php?f=13&t=72863 Working from home...
C6 is 25.75"
M5ODR2 is 27.625"
<sigh>
<sigh>
-Thank you
