99 Ranger 2.5 Fuel Pressure Specs
Tracy CA
Does anyone have the fuel pressure specs / procedure for a 1999 Ranger 2.5??
60 to 65 psi they will run on anything above 45 psi but will be low on power. what procedure are you looking for?
Actually I figured out how to do this. The pressure was 66 PSI with the car running. I turned the car off and let it sit for 1 hour; the pressure dropped to 30 PSI. After 2 hours the pressure was 0 PSI. Under partial throttle; the truck will hesitate at times (full throttle is ok). I was able to make the truck hesitate under light throttle when the fuel pump tester was on the car and the fuel pressure only dropped to 64 PSI. So I guess I have a leaking injector or a bad check valve in the gas tank. FYI, the truck is throwing no trouble codes. Also I just COMPLETELY tuned it up with Motorcraft parts (plugs, wires, pcv, fuel filter, air filter). Any thoughts? Thank you !!
Also, I did the leaking injector test....Attempted to start the truck with the gas pedal to the floor.....The truck would not start at all.....Which leads me back to the fuel pump check valve,,,,
you thought of the iac. if it is sticking it would cause a hesitation
Loss of, or limited, power at highway speeds is a fuel pressure issue, or dirty fuel filter
Hesitation is not
Clean MAF sensor, once a year
Check TPS(throttle position sensor), easiest/best way is to get a Bluetooth OBD2 reader and free APP, under $20, with with any vehicle sold in the US or Canada since 1996, so not a Ford thing/tool, ANY vehicle
You can test all sensors with this tool, and read codes, and clear codes
Key on/engine off
TPS should show about 17% with foot off the gas pedal, if you touch the pedal it should instantly show that by going up above 20%, and at Wide OPEN(foot to the floor) it should show just above 90%
The TPS gives the engine computer a "heads up" that throttle just opened so computer needs to instantly add more fuel and change spark timing
Without this "heads up" you would feel a hesitation
TPS is just a "volume control or light dimmer" a variable resistor, so can get dead spots, very unlikely but best to test for it
DO NOT replace the TPS, until you test it, just throwing money away
Check the Cam Sensor connector, on drivers side behind timing belt AUX gear, unplug it and plug it back in
Cleans the contacts
When was timing belt last changed?
They are good for 100k miles, an old belt can cause hesitation
Yes the drop to 0psi after a few hours would mean there is a leak in fuel pump assembly, check valve is inside/part of the fuel pump, not a separate piece
If engine is hard to start cold, then turn the key on and off 3 times, then try to start, should start right up
Just had to replace my MAF, exact same symptoms.
