Jim Oaks
Just some guy with a website
Founder / Site Owner
Administrator
💻 TRS Socials
TRS 25th Anniversary
- Aug 2, 2000
- Age
- 58
- Nocona
- State - Country
- TX - USA
- Other
- 2005 Jaguar XJ8
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 2.3 EcoBoost
- Total Lift
- 3.5-inches
- Tire Size
- 295/70/17
I've been asked this a few times and figured I would post it here for reference.
Question - Why can't I find a suspension lift for a 1995 Ford Explorer?
Answer - The problem on the 1995 Ford Explorer is the rear torsion bar mounts. Ford welded the rear torsion bar mounts to the frame. From 1996+ the mounts were bolted on.
A Superlift kit could be used, but you would have to cut the mounts off of the frame.
Superlift does not recommend their kit due to the difficulty of properly aligning the mounting brackets for the torsion bars. The reason for the new torsion bar mounts is to lower the rear of the torsion bars to equal the height of the front of the torsion bar. There is also a bracket that drops the lower control arms so the front axle shafts are not at too large of an angle.
So in a nutshell, if you're looking for a used Ford Explorer and have a desire to lift it, stay away from the 1995 model year unless you want to do custom fabrication.
Now you know.
Now you know.
