- Mar 6, 2020
- State - Country
- MI - USA
- Vehicle
- Ford Ranger
- 4.0 V6
- Total Lift
- 1-1/2 inch front leveling
- Total Drop
- Stock
- Tire Size
- 31/10.50/15
- My credo
- What's the worst that could happen?
I have a 40x60 pole barn which is used for storage, firewood and to park cars, trucks, the tractor and a variety of lawn and garden mowers, tillers, etc. When i built it, I had 40 feet of it concreted and left about 20 feet with sand and packed gravel. That's where I park the tractor and other leaky things - although the cars and trucks leak more than the tractor. Lately, I've been thinking of laying concrete in that area as well. Then insulating and adding heat so I can work on stuff year round.
My initial list is 6-inch concrete with rebar. Haven't decided on insulation - either spray foam or the standard pink stuff. Covered in OSB and sprayed bright white. I'll also have an I-beam with chain fall. For heat, a wood stove or propane fired overhead burner. I'm leaning toward wood cause I have an ample supply.
It's ten feet high so I think I could go with a floor hoist, but not sure about the expense and the additional concrete support that might be required.
If you were doing this, what would you do?
