- Jan 18, 2021
- Chattanooga, TN
- 4.0 V6
- Tire Size
- 235/75/15
- My credo
- Get the job done, correctly, the first time. There's beer to be had.
Look at the below photo. Coming out of the back of the shift motor harness plug, there is a single brown wire that runs just in front of the fill plug and terminates in the rear of the t-case rear driveshaft output. I've looked at both the shift motor rebuild writeups in the tech section but haven't seen any reference to this wire. I believe it to be part of the clutch sensing circuitry but I can't be sure.
BW 1354-22 tcase attached to a manual transmission.
I'm trying to rebuild my motor since I'm getting the 6-flash error. 4WD was working two weeks ago without issue. I suspect it may be that little plastic bushing inside the ring gear which serves as a limit stop. I want to remove the motor and give it a good service but I don't want to yank out this brown wire until I know what it is.
Thanks!
Thanks!
