What was the stock tire size for '93-'97 2.3 4x4 Rangers?
outatime88
10+ Year Member
California
3/4
I've tried looking around, but couldn't find a real answer. I know for sure that they all came with 4.10 gearing, but did they come with 215/75R15 or 235/75R15 tires? Here's a snippet from a brochure below:
54166
225/70R14 for my 4.0 97, but that's the Mazda version, so no idea if it is the same for Rangers, or for other engine sizes. I had a friend with 4 cyl version of the Mazda of about that vintage and the tires looked equally dinky, compared to the 235/75r15s I put on mine after changing the wheels.
I have it in my head that a year or so later they went to 15" wheels from the factory.
Edit: duh I looked at the thread title again and realized its for 4x4.... so ignore my post.
14 or 15 wheels? I think on 15, they were 15x7, and the max recommended for a 7 width is 225/75-15. But I know a lot of folks run the 235/75-15. That’s what I have on my 87 4wd, 93 2wd and 97 2wd. Not sure on 14, I think they’re 14x6 or 6.5.
if you know your wheel size, forget Ranger and google “maximum tire width” and you’ll find some good tables.
also, not sure 410 is universal. My 87 (2.9) is 345.
hope it helps
54168
215/75R15 is standard, everything else is option or package (which I suppose is sort of an option)
hope it helps
4.10s were only ratio available in 2.3 4x4 Regular cab (Regular cab is redundant - you couldn't get 4x4 and SCab in 4x4).
But was the 235 tire package an option for the 2.3L 4x4? I know it came with only 4.10 gearing so I feel like that would mean it could only come with one specific tire size as there was only one gear ratio available. I could see there being multiple options for the 3.0 or 4.0 since there were more ratio options, but I want to know if it was available for the 4 cylinder.
you should have a sticker inside the driver door (provided the doors are original) that should give you the factory tire size for that truck.,
AJ
AJ
Unfortunately my truck is a 4x2, but I am planning on putting a 4.10 axle in. I wanted to know the stock tire size so I can match it to how a 4x4’s performance would be from factory.
"Performance" (or lack thereof) in a 2.3 liter engine is a relative term.... just sayin' ;)
Buy what you want, it's your truck.
Consider this.
Obviously, the 2.3 has less power and torque than larger engines. The universal use of the 410 rear seems also obvious to maximize the torque and off-the-line performance of any 2.3 truck, 2wd or 4wd.
Tire size is a personal choice based on what your goals are with that particular truck, your truck, your choice. If you’re 100% concerned with an aggressive appearance that mimics a 4wd, an aggressive all terrain 235 15 is the ticket. If your looking for pulling power, low end torque is probably primary, so a wide low profile tire (225/60-14) will give the best”ratio” between the engine and the pavement, but they may look anemic. It’s obviously about balance, but not what we think, it’s what you desire.
Me, I love playing with many toys, and I worked hard and smart to be able to afford them. I’m definitely into the “image,” but ONLY ONLY ONLY after the performance I need and want, so I want adequate performance from something that looks cool. I’ve realized a lot of the TRS guys definitely are in the “bigger, stronger, faster, shinier” mantra, absolutely nothing wrong with that. My girlfriend’s son is happy with a rusty little trailer behind the kiddie van, and momma makes him paint the hitch every time he uses it. This is the whipped philosophy.
I suggest this if you’re on a budget. You can buy dirt cheap steelies or get them free if you cruise Craigslist and just search around. Then find some almost worn out but legal used tires ($10-20 each) and mount them up and drive around a while. Try a small set and try a big set. It’s usually $10-15 to mount the tires. From the small vs large comparison, you could probably zero in on something in the middle. But try that with a used set too. Then, if you like the balance of ride and performance, spend the money & sell all the used tires and wheels for what the cost you (or keep them for snow tires). Trust me, a balanced set of legal tires on Ranger rims will sell, even if worn. Maybe paint the rims in 3 minutes with black or silver Rustoleum.
Modify this to your needs and memorize it so when your buddies rag you, you can show them your process to get it just right so you don’t end up with $1000 of wheels and tires you don’t like (like them)!!
One last thought: you might be able to fool the minions into thinking your truck is a four-wheel-drive, but anybody with a brain is going to know it’s not. Don’t kill yourself by thinking you can kid everybody. It’ll be much more cool if you make your truck the best truck it can be, maybe a little bit different to draw attention.
& keep doing what you’re doing. It’s called research, it works, it saves time and money. This is fundamentally the right place and people (but if you’re getting your wisdom from me 🤪...).
Hope it helps.
Keep in mind that the 4.10 gears are probably the lowest gears Ford had for that axle. I know you can get aftermarket sets lower, but the pinion gets awfully small (makes it weaker).
If it would have been practical for Ford to go any lower, they probably would have, especially on a 4 wheel drive.
With a 2.3... if Ford wanted to they could have.
Guys run deeper with non OEM powertrains and for the most part get along ok.
If it helps any I want to say my '85 with a 110hp 2.8 (I think by the 90's the 2.3 had more power) came from the factory with something like 215/75-15 and 3.73's. It got around fine with 235's.
Do aftermarket gears lower than 4.10 have to have a tooth on the ring gear ground for clearance to get the cross pin in? I think that was in the form re: the 8.8 axle, but I could be mistaking the two.
No idea. I seem to remember that for a lunchbox locker for some reason.
I suspect it could be a volume thing too. The 15 guys that bought 4cyl 4x4's would not be worth building special gear sets or carrier assemblies for.
I have never been around one, my rather weak 2.8 got around pretty good with 235's and 3.73's though so I doubt deeper than 4.10's on a more powerful 2.3 would have been too badly needed.
And if you go higher than the 410, your engine is going to be screaming trying to go 70 miles an hour down the road.
