lil_Blue_Ford
Cut & Weld
⭐Supporting Member
💻 TRS Socials
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Total Drop
- 4”
Used the 92 to fetch a new wheel cylinder, then installed it and bled the brakes. Of course, the axle seal on that side is leaking which I only found when I pulled the drum. So I guess that goes on he repair list. Also found a small crack starting in the frame, the one front spring mount is rotting and I have a bad front U-joint.
