Years ago I acquired a old Lincoln stick welder. I finally got the itch to drag it out and play with it, usually whenever I think about it it is either 300* outside or the barn lot is a swamp or for some other reason it is easy to talk myself out of messing with it. It was in a shed at my parents so I had to drag it out of there and I took it to work to clean it up and see if it worked.
Kinda weird, most of them (my dad's included) have a 120 setting at the dead center between my 115 and 130 settings. Not sure if that makes mine older or what. Dad also has the rod use chart as part of this panel whereas mine had it on a decal on the top like the current ones... so I really have no idea if mine is newer or older than dads.
Dad's is like this:
No mouse nest at all, I am very impressed!
The "computer" looks pretty good too.
20.2 pounds of spider webs shop-vacced out.
The two back panels actually can come off separately which makes it come apart much easier.
Hit it with some quick detailer to spiffy it up a little bit
The previous owner extended the cables because he had to weld something on his combine which obviously would not fit in his garage. He laughingly described it as having "the longest cables in the county" Probably not wrong, at least 50'... they are a beast when they get tangled up.
And it works!
Not pretty but since nobody can remember how old the rods are (very rarely use the stick welder at work anymore), I haven't welded since George W Bush's first term and I only got a half hour of practice in... I WILL TAKE IT!!! Getting my speed and feed are weak spots, I am doing better but I kinda got chased out for stinking the place up.
Just gotta change the end yet, at work we use the angled plug like what it has on it, my garage as the giant normal looking plug for 220.
So anyway, more neat old stuff. I need to get a helmet and get it to warm up out so I can play with it more.
And since I still need to get the stupid exhaust rerouted on the Ranger so I can leave the front driveshaft in it full time... the F-150 got to play drift buster yesterday.
