- May 1, 2018
- Seattle, WA
- 4.0 V6
Been trying to track down a leak on my M5OD. Seems like the neutral safety switch maybe leaking. I replaced the switch and RTVed the threads hoping it would solve the issue. The new one seems to still be leaking. Is there a seal or O-ring behind this switch that could be the issue?
I thought it might be the Top cover plugs but when I pulled the shift boot to look they don't look like they are puddling fluid. They were pretty stuck in when I did the clutch two years ago and I added more RTV to the lip of one of them after unsuccessfully trying to remove it with the trans out. Not sure how much would just be drip back from the switch here if that's the issue.
I have a new top cover seal on order and the doorman plugs to swap the plugs. I was going to try pulling the carpet back and swapping the plugs and seals from inside the truck, but it really looks like the neutral switch is leaking and maybe my issue. Did I just get a bad switch? Thanks.
