We don't "poo-poo" cold air intakes. The problem is that most aftermarket cold air intakes suck hot air from the engine compartment. Your truck came with a cold air intake system that brings in air through the radiator core support, behind the headlight or between the inner and outer fender. So it is a true cold air intake. However, as noted, it is restrictive. So if you can replace its tubing with larger tubing that matches or slightly exceeds the diameter of the throat in your throttle body, you may make it easier for the engine to breathe. It will also sound louder. But putting on a cone filter that sucks hot air from the engine compartment will not be an improvement.
