My temp gauge is always right below the half mark. I connected my scan tool for unrelated reasons and noticed my coolant temp was actually high. Its averaging 245 to 250. I had no idea it was running hot. What the heck
It says ect. I have it plugged into the obd 2 portWhere is your scan tool reading the temp from?
Check resistance of your ECT sensor when at operating temp and when shut off for 12 hours. Report back.![]()
......we're not friends anymore.2.3l Duratec(2001-2011 Rangers) uses a CHT(cylinder heat temp) sensor not an ECT(engine coolant temp) sensor
So 245-250degF is OK
Yes, 204deg on upper hose outlet is correct
Temp gauge on dash has 210deg as 1/2 way
Damnit you polite Canadian bastard, I guess were friends again.I like Dodge cars, and I did own two Rangers with 2.9l's, that ran well![]()
Awesome thanks! So its misleading for my scan tool to say ect in this case
