I have replaced the battery, starter, and terminal connectors, and the truck still will not start. It has the 2.3 Lima I4, M5OD, and 4x4 with manual-transfer case.
The fan blade does not change position; the headlights, taillights, auxiliary lights, interior light, turn signals, and instrument cluster work. I turn the key, and I can hear the solenoid/starter engaging, but there is no combustion to start the engine. The timing belt remains stationary, so its components (alternator, belt tensioner, fan clutch, idler pulley, and water pump) are not operating, either. This Lima does not have air conditioning nor does it have power steering. It has manual-window cranks, a manual transmission, and a 4x4 system with a manual-transfer case and manual-locking hubs. There are no additional or after-market electronics or electronic components.When you say the engine " won't turn over" do you mean that the fan blades never change position?.....or do you mean the engine spins but won't start?
bare bones truck! XL no turnove means just that, no movement of anything.. .. Did you charge the new battery before install? ALWAYS.. right now it sound like you are using only the jump power from the other truck which is also bein leaned on by the " new " battery" On top of that if you did not get a decent size battery and bought a cheapy it doesn;t have enough amps to crank new motors,. you need 600cca AT LEASt. and it also sounds like your grounds are weak. ther should be good cable to core support by battery another one to the frame from the battery neg. then a strap from the wiper motor to the firewall and another from a startbolt to the frame, besude the regular neg cable to block. and all thes are SUPPOSEd to be on these trucks other than maybe the starter bolt, but it your case it could be the fix.. Bad grounds are notorious for wantin the kiss principle...... Again ALWAYS charge a new from the store battery at no more than 10 amp[ less is better] and overnight.
