- Jan 6, 2002
- Pittsburgh
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 2.3 EcoBoost
- Total Lift
- 1.5"
- Tire Size
- 265/70-17
- My credo
- "220, 221, whatever it takes."
I need to see the science on this space man.Thats why you put some isopropyl alcohol in the tank in the winter. The isopropyl stops the phase seperation of the ethanol/water and gasoline.
I always understood Isopropyl Alcohol suspends the water in the fuel so that it can be sent to the engine for removal. Also prevents the water from freezing during winter causing a line blockage prevent the engine from running.
I'm not to sure what you are talking about the "Phase Separation" of water and Ethanol though.
Only place you can buy it here is the airport and the marinas for about 3.75 a gallon.![]()
I ran 91 non-ethanol in my 5.7 tundra almost exclusively while living in Montana. Never noticed much, if any, difference between it and ethanol blended 91. Always ran premium, never tried it with 87. Like has been previously mentioned, the ethanol may help with removing moisture/water from the fuel system.
Regarding the efficiency of corn gas..
Straight ethanol can only ever be about 70% as efficient as gasoline, so it would give you 30% drop in mpg were you to run it in anything.
Pump gas nowadays regardless of octane rating is mostly e-10 (10% ethanol). With only 10% ethanol you'd only see a 3% decrease in fuel economy. 3% is a pretty negligible figure, even on one of those fancy 100 mpg carbs.
