Jim Oaks
Just some guy with a website
Founder / Site Owner
Administrator
💻 TRS Socials
TRS 25th Anniversary
- Aug 2, 2000
- Age
- 58
- Nocona
- State - Country
- TX - USA
- Other
- 2005 Jaguar XJ8
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 2.3 EcoBoost
- Total Lift
- 3.5-inches
- Tire Size
- 295/70/17
Hey all,
I'm trying to get the 302 in the old Ranger running good. It has been sitting for over 2-years and only hit the trail a few times a year prior to that.
The 302 has a Holley offroad avenger carb. MSD 7 ignition module and wires, and split fire plugs.
It idles good with steady vacuum.
When you hit the gas to rev the motor in park, it bogs down. It doesn't bog off idle, it seems to start to rev and then bog.
I replaced the fuel filter and regapped the plugs to .035. The factory setting is .034.
The holley has a 'window' in the side of the float bowl and you're suppose to see the fuel at the bottom of the window. I've tried adjusting the float level with the adjusting screw/nut on top of the bowl. Doesn't seem to make any change in the window, but I did turn it up to much to where you could hear the fuel pouring in to the carb and had to turn it back.
The holley manual doesn't give any information on the accellerator pump.
I use to be able to pull off a pretty nice burnout with the truck. I need to get this fixed so I can start flinging mud next Friday.
Anyone have any suggestions? How much could 2-3 year old gas play on the problem? It was probably at about 1/4 tank and I added another 4.5 gallons to it.
