Do i need LDS friction additive in my '98 7.5" rearend?
racer190
Getting ready to change out the rear diff. fluid and was wondering if i need to put in the friction modifier along with the gear oil?:dunno: It is a '98 ranger XL 2.5L with 5 speed tranny. Thanks
does it have a limited slip, doubt it for an XL, just look at the tag on the rear axle, if it says something like 3 73 then NO if it says 3L73 then yes. so if a L is inbetween the gear ration then yes, if its not then No
No, you don't NEED friction modifier in a L/S diff. It may chatter around corners but won't explode although I swear mine feels like a tooth is missing in a side gear sometimes !! LOL !!
Look at the tag on your drivers door, under axle if you have a letter and a number you need friction modifier if you want the L/S to work properly. Bent Bolt is just using some thick Alberta Tarsands crude in his diff.
Kona, we've been over this before. It doesn't need FM, the used clutches aren't going to chatter, I guarantee you. However new clutches would chatter if not soaked in FM before installation. FM is to keep soccer moms from bitching. It WILL work better without FM.
How'd you know ??:icon_confused:
I live in BC , we get lots of Alberta refugees
But I like the stinky smell of Ford LSD additive :stirthepot:
北京金诚信四方卡识别技术有限公司5
清洗磁头①将干净洁卡的毡面紧靠磁头在导槽中划过5—10次。②如果认为磁头已结成污垢排队机可先用清洁液或酒精浸湿清洁卡的毡面ic卡读卡器让毡面紧靠磁头在导槽中划地几次。2、清洁编程器滚轮①用清洁液或酒精浸湿清洁卡的毡面叫号机将毡面紧贴滚轮在导槽中划过一般10次即可。②用干的清洁卡再划2-3次。3、清洁导槽①用纱布缠在清洁卡上放放导槽边缘。②将卡送入槽内到达磁头边沿为止取号机在磁头两边移动清洁刷卡器但不要碰到磁头上。③注意清洁完毕不要将纤维留在槽内或磁头上
Its fondly referred to as Cat Piss at my dealership.....as stated tho, it is not needed, and will not harm anything not using it.
