- May 18, 2020
- Burbank,CA
- 4.0 V6
- Total Lift
- skyjacker front leveling kit
- Tire Size
- 31-10.50R15
- My credo
- Crossed threads are tight threads.
I want/need to do the "big 3" wiring beef up job.... and seeking some pre-attempt feedback.
First off this is a 4.0 ohv, running stock 95amp alternator. I plan to run an explorer 130amp to power a few extra things.
I plan to add an electric fan, some lights (small lightbar and some lil square LED's, nothing crazy), and maybe eventually a small stereo, like well under 1000w. Maybe even just a 200w subwoofer.
Will 130 amps be enough for the above mentioned? or bite bullet and go for 200+ amp bad boy?
What else should/can I rewire relatively easily besides the big 3 ( +alt and battery cables and the grounds)?
Also....
What gauge wire would you recommend? Whats the best wire out there as far as continuity, flexibility, heat/weather resistance, insulation etc....Stereo/audio stuff? Welding supply stuff? Marine stuff?
Where and what size fuses should I use? I'd rather go overkill w/ fuses/relays than risk a meltdown.
Any battery terminal recommendations?
Anything else I should know will be appreciated. Pics would be awesome.
I have read many threads on this topic from various forums, and ended up with a mountain of questions....hoping this will reduce it back down to a molehill of a few wires, connectors and fuses.
Also....
