- Nov 7, 2019
- Age
- 30
- Georgia
- 2.8 V6
- Total Lift
- However much it goes up when I get my fat ass out.
- Total Drop
- How much it goes down when my fat ass gets in.
- Tire Size
- Dry rot and old
This is the state of my starter mounting. The separator plate is worn out and a bit deformed. It keeps allowing the starter to move away from the flywheel and causing it to grind and not be able to start the motor. I've read posts upon posts about how people having a similar issue and some say tighten it till it can't move anymore. Some say replace the plate. Ive tried tightening the hell out of it. It still seems to move, I've tightened it will thread locker still moves. So atm, I can't even drive my truck let alone set the timing after the duraspark mod. This is getting annoying and fucking with my depression. Like I know what the issue is but whenever I try NOTHING WORKs.
If anyone has any ideas on what I should try or do based on their own experience please tell me or if anyone knows or had a separator plate I WILL BUY IT!! That's if it will fix it!. I've had an idea on a bracket to make that will hold onto the top and bottom bolts and pull on them and in turn, push on the starter by push pulling the starter in place. Keeping it from moving. The only issue with that. Is that I don't know how to or own a welder to try and fabricate something like that. I'm desperate at this point!
