- Jan 7, 2020
- Age
- 31
- Hickory NC
- 2.9 V6
so I'm running Ritch like fuel leaking out the tailpipe Ritch. If my ranger was an SR-71 Blackbird I'd be ok with it. Buttt its not and 9 miles to the gallon sucks. So I have a couple questions.
1. Does the high pressure inline pump run full time while engine is running?
2. If I have a fuel regulator on the incoming line set to 40psi would that eliminate the need for the return regulator? Or do I need to put it on the return side.
3. Could my valve duration be off?
