- May 29, 2019
- Southeastern PA
I was attempting to diagnose the DPFE sensor in order to figure out why my truck is throwing an EGR related check engine code. But I went to start the truck with back probes installed on the electrical connector coming from the PCM and it wouldn’t start. The lights on the dash turn on and shit, but the starter doesn’t want to turn over.
i do have issues occasionally with the starter not wanting to engage or needing a jump. My oil pan is leaking.. and gets the bottom ring terminal (which is the hot lead?) for the starter wet. But I made sure to clean it off and tighten it up. Nothing though. I even tried manually jumping the starter on the solenoid. And my buddy tried pop starting the truck (it’s a 5spd) and that didn’t even work.
Kind of at a loss right now, I left the truck at work yesterday Which isn’t a big deal for a couple days while I figure this out.
another note: I tried using my crappy Bluetooth OBDII reader to connect to the truck, but it wasn’t connecting..
