'85 Ranger Restomod
Rear bumper is CUT!!
'85 Ranger Restomod
Just need to measure it up and get some plate to fill it in. And reinforce it for the tire carrier and figure out how to mount it, and make a spare tire carrier and and and...
'85 Ranger Restomod
Famous last words.
“All ya gotta do is...”
After the 5 speed swap I had a vibration on hard acceleration at around 3k rpm... aka about when the secondaries kick in. Kind of a wild goose chase on a truck that set for almost a year. I checked fuel filters, fuel pressure, took the fuel pressure regulator out that I added while it was down. Changed plugs, checked just about everything.
Eating at me in the back of my mind was the fact that it seemed like the trans sat a light higher than the A4LD/C5 did on the crossmember, like the trans was thicker between the output shaft and where the trans mount goes. I checked the angles and everything checked out at the time though.
Well the springs were weird, maybe it is spring wrap combined with the weak springs. So I did the rear suspension upgrade. It helped with accel but now I had a light vibe at highway cruising speed. Loosing ground but I have something to go off of now. So I check it again with my analog angle finder (used the level app on my phone the first time) and low and behold... I am way off.
Well crud, now what? I look into pinion shims, quick cheap and easy. No dice because I have the extra long "anti-wrap" Ruffstuff spring perches that are 8" long, the longest shim I could find was 5". Then I was scrolling on here and noticed a guy with a second gen, it looked like his transmission crossmember was lower and they used a thicker trans mount to make up the difference. Now we are on to something. Except that there is no downward adjustment left with my crossmember.
So I dig the crossmember out of my dad's grainery and flip my pickup box trailer in process up on its butt and measure.
'85 Ranger Restomod
Gonna call that 1-1/2" above the bottom of the frame.
'85 Ranger Restomod
So then I crawls under my truck, the perspective makes the top look weird but I did my best to line it up. 2-1/2", a full inch different!
'85 Ranger Restomod
Ok, lets call that a plan B. The brackets on my trailer are very rotten and riveted on the frame to complicate pulling another set from a yard. The second gen mentioned earlier bolts on, easier to pull and easier to mount. So I hit the JY.
The least crusty one there was in a '93 Explorer. I did measuring back and forth and the frame doesn't get wider until RIGHT after the trans crossmember. I also measured it to be 1-3/4" above the frame. So I give up a quarter inch of adjustment to get a much easier to work with crossmember.
'85 Ranger Restomod
Still nervous about the frame thing I compared to a 2wd third gen, same same. Also eyeballing it for fitment it looked to be about a quarter inch higher.
'85 Ranger Restomod
Back to the ranch I head with my treasures:
'85 Ranger Restomod
Before I start I measure just for giggles:
'85 Ranger Restomod
Look ma, no crossmember!
'85 Ranger Restomod
'85 Ranger Restomod
'85 Ranger Restomod
And it bolts in! I think the holes are there for dogbone style crossmember and this one uses two on the passenger side, kinda neat.
'85 Ranger Restomod
Or almost bolts in... had to break out the die grinder.
'85 Ranger Restomod
'85 Ranger Restomod
'85 Ranger Restomod
And it is down 3/4" on the nose.
'85 Ranger Restomod
Crossmember is holding the transmission:
'85 Ranger Restomod
Angle still is not ideal. Pinion is up 1.5* compared to the transmission. I suppose without the Belltechs it would be right on. Given I have dropped the trans a ton I am going to give it a go and see how it is. I need to work on the t-case mount yet but otherwise I am optimistic so far.
I had to modify the t-case mount so it could sit lower, and drill new holes in it. It fought me every step of the way but I got it back together. I went to hook the driveshaft up... and it barely goes in. The thing is like less than 1/4" from full compression now.
'85 Ranger Restomod
So now I gotta deal with getting the *&*^! driveshaft shortened AGAIN. :temper:
Do a v8 swap they said.... It'll be fun they said....
Fun fact, at around 49 minutes left in the video, in the left aisle about four rows up from the bottom, the blue one behind the white one clear to the right/inside... that is the '93 Explorer I got my crossmember from last weekend.
You set that poor junkyard on fire!?!
I will neither confirm nor deny these heinous accusations!
Looks like it is back behind the curtain where they prep them before they go into the yard, the drain the oil and stab the fuel tanks/tires building.
Target of opportunity on a truck with no bed today:
'85 Ranger Restomod
'85 Ranger Restomod
Yay... looks like ya got all of it.
You will NOT regret that. Both of mine have B2 rear bars for a reason 👍🏿
There are a ton of different links out there for em. IME, the 276mm ones work better for 1750lb rear springs.
Common import trick is to have multiple holes to mount the bar to the links. Move links closer to the axle for softer, further from the axle for firmer.
Interesting.
All I know is the hole in the frame that was in a great spot for my parking brake cable bracket is for the sway bar. I have figgered that much out so far.
Not many BII’s around me anymore. I have NEVER seen a 2wd alive or dead.
I will probably just disconnect them for serious off-roading.
Ebay for the one on the 2011, and managed to find one in the JY. By time I went back for a second round on it, only thing left was the carpet, dash, bare shell, and hood. That one got picked CLEAN.
Rear sway bar is blown apart:
'85 Ranger Restomod
Cleaned up and painted:
'85 Ranger Restomod
I picked up some exhaust clamps for the u-bolts, those are painted as well:
'85 Ranger Restomod
End links are painted too.
New shocks are on the back too!
'85 Ranger Restomod
