As the title says, will the defrost work at all or will it half way work? I have recently acquired an 1987 2.9L 4x4 STX with factory manual hubs and a manual trasfercase for a killer deal, witch the truck needed a little work. Got it up and running pretty good this past weekend with a little TLC, but this truck will be a spare/beater truck for myself, I try to keep things as simple as possible and I like having plenty of room under the hood to work as well and I plan on installing the largest trans cooler that will fit behind the grille if I remove the condenser.
For those of you who have deleted the A/C, will the defrost work at all? Will it barely work or is better to just leave the compressor there? I don't have to have the A/C at all, the A/C system works, just needs a charging to get it where it should be. Trying to get some input on this before I make my final decision.
Thanks in advance.
Thanks in advance.
