Mystery tool thread.
Are turd knives really a thing? Honestly? I've heard them referenced enough by this point to believe they are.
Apparently having a "kissing cousin" is "normal" too? Are these the same types of people?
Dude.
It's 2020
Normal is loooooooong f***ing gone.
Also, tool was a cement bond tool. It's essentially a downhole sonar that uses piezoelectric transducers to detect whether or not there is cement (or "stuff") bonded to the back side of casing within a well.
Since when is the occasional need to break up a big poo so it'll flush not normal? That's been a thing since toilets were invented.
Back on topic....
Sound a lot like Autotune. No lie.
Hua. So, sounds like they repurposed the attenuation equations that run reservoir sondes or seismic survey equipment. Cool.
I've seen the corkscrew looking things used at county fairs. Stick a hot dog into them and on a cutting board run a knife blade in the grooves as you run it across the board. Gives the dog a cut along its length.
Don't know what the comb looking thingies are.
Grumpaw
The comb is for combing the hair on a breadless cut hot dog
You're both wrong! They are for performing clown circumcisions.
That's clearly a urethra scratcher
