More terminology
My buddies and i have also bendix for a whule now.šŸ˜‰
I'm gonna need you to go ahead and stand in the corner for what is possibly the single worst pun in the history of mankind. Go on... go think about what you did...
My hat’s off to you guys who have to fix customer cars, I don’t have the patience. There’s a reason why I rarely listen to music in my cars, it’s because I’m listening for the next thing that’s not quite right. Chances are by the time I get home I know within a few things what it could be - I’ve already figured out what that sound correlates to, and knowing how it works there’s only a few possibilities. How in the hell do you do that after filtering through layers of ignorance and idiocy?
Standing in the corner and loving it
Just stand in the corner and cry... you’re not allowed to enjoy it!!
Nobody ever said I can't enjoy my punishment
iu
Does jack have a hitler mustache?
Only question that needs to be asked is........."What color is the car/truck?"
If the answer is not RED then you found the problem
Simple solution, paint it RED, then it will run fine....................forever
Now that's science
All Rangers are RED, any other color is just primed waiting for the final coat of RED
So if yours is not RED then it wasn't finished at the factory, try to get your money back :) or paint it RED yourself
And its why Rangers last longer, its because they were all build like a RED vehicle, but without that final coat you can have break downs
My 97 is Red. we are good.
AJ
Actually on an older Ford the solenoid is on the fender and it sends power to energize the field coils which pull a metal weight down and forces the starter drive out so it meshes with the ring gear. Old guys(older than me) will often call the starter drive a bendix. They both drive the ring gear but they're far from the same thing, a bendix is spinning when it hits the gear and a starter drive engages the gear before the starter spins.
Regardless, the device on the fender is a relay not a solenoid.
