- Sep 22, 2007
- Michigan
- 2.9 V6
- My credo
- A legend to the old man, a hero to the child...
Went and got lumber today....now the real fun *sarcasm* begins...
Oh i fully expect to find that out lolIt's never enough 2x4's.....
No.You're out of 2x4's....
Only difference in a 4x4 and 4x2 is about 30 feet of strap.But he has plenty of 4X2s to work with.
Im not using R19 on the ceiling. I was asking what yall recommend lolEven with only heating the space for an hour or so at a time, more insulation in the ceiling might be worth consideration. It will take more energy to heat up and maintain the heat in the space with less insulation. One has the balance the initial cost of the added insulation to the cost of whatever you are using to heat the space in the long run.
My garage is uninsulated at the moment and uses a lot of kerosene and propane to warm up and maintain heat. I want to insulate the garage at some point because of that. Very cold days, it's all I can do to just keep the temp around 50 degrees in there as a result.
