So here's some coil spring specs thanks to Moog:
Ranger:
Accoring to Moog, a 1996 Ford Ranger extended cab 4.0l 4x4 has a coil spring that is 11.5-inches installed, and 13.47 inches free. 485 spring rate / 899 load rate.
The standard cab version has a coil spring that is 10.5-inches installed, and 13.75 inches free. 430 spring rate / 1,447 load rate (also comes as 377 spring rate / 1,323 load rate)
The 2wd standard cab short bed 4.0 has a coil that's 10.5-inches installed, and 13.75-inches free. 430 spring rate / 1,447 load rate.
The 2wd standard cab long bed 4.0 has a coil that's 10.5-inches installed, and 13.94-inches free. 489 spring rate / 1,650 load rate.
The
Skyjacker 6-inch coils are 18.875-inches free, and have a 435 spring rate.
@ericbphoto has a Skyjacker 6-inch lift on his 1993 standard cab Ranger, and he's measuring 16.50-inches. That means he has a true 6-inches of lift.
@4x4junkie has a skyjacker 6-inch lift on his 1994 standard cab Ranger, and he's measuring 14.8-inches. That means he has 4.075-inches of lift.
@Kona has a Skyjacker 6-inch lift on his 1991 Ranger, and is measuring 14.50-inches . That means he has a 4-inch lift.
Myself, 4x4junkie, and Kona all have extended cabs with heavier bumpers, and winches. Do the bumpers and winches really cause the 435 spring rate springs to droop 2-inches, or have they sagged over time from the added weight?
If I have coils that were 13.75-inches free, the Skyjacker coils should supply my Ranger with a 5.405-inch lift. They only give me 4-inches of lift (14.50 inches installed).
Oh ya.....,
Spring Rate is the amount of weight required to deflect a spring one-inch, making it a measure of softness for the spring.
Load Rate is the amount of weight a spring is designed to carry at a certain ride height, making it an engineering consideration.
F-150:
1986-1996 Ford F-150 4x4 coil springs are 13-inches when installed, and 16.38-inches free. 366 spring rate / 1,230 & 1,428 load rates.
1979 Ford F-150 regular cab 4x4 coil springs are 13-inches when installed, and 18.25-inches free. 271 spring rate / 1,575 load rate.
The TTB F-150 coil springs should give a Ranger a 2.63-inch lift.
The solid axle F-150 coil springs should provide a 4.50 inch lift.
Bronco:
The 1986 Bronco 4x4 coil springs are 12.125-inches when installed, and 16.18-inches free. 366 spring rate.
Econoline Van:
The 1975-1987 Ford E-250/350 coil springs are 15-inches when installed and 18.88-inches free. 420 spring rate / 1,650 load rate. This spring should give my Ranger 5.13-inches of lift, and is slightly softer than the Skyjacker 6-inch coil (Skyjacker 6-inch coils are 18.875-inches, and have a 435 spring rate)
The 1978-1991 Ford E-350 coil springs are 16-inches when installed and 19.27-inches free. 549 spring rate / 1,797 load rate. This spring should give my Ranger 5.33-inches of lift, and is stiffer than the stock spring due to the 64 ppi spring rate difference.
What Does This Mean:
I have no freaking idea.
Actually, my biggest question is what affect the
Load Rate has on any of this. People have said that the F-150 coils were stiffer, but they have a lower
Spring Rate than the Ranger coil. AND, the F-150 has a 1,230 & 1,428 load rate versus the Ranger standard cab 1,447 load rate.
Reminder:
New Coils or Spacer?
Skyjacker doesn't offer 8-inch coils anymore. Replacing these coils with a new set of Skyjacker 6-inch coils is just going has the same result over time. The 1977-1987 Ford E-250/350 coil springs should give me a 5.13-inch lift, but has a softer 420 spring rate over the stock extended cabs 485 spring rate. Their even softer than the Skyjackers 435 spring rate. They're $77 for a pair at Rock Auto. Skykacker 6-inch springs are $195.
The 1978-1991 Ford E-350 coil springs should give me 5.33-inches of lift, but have a higher 549 spring rate.
There's also an idea of 2-inch Skyjacker lift springs for an F-150 that should provide 5-6 inches of lift, but they're $165.00
