No one called you a liar, I don't think you had the intent to deceive anyone, you just misinterpreted some information
Many engines share a common bellhousing pattern, Small Block Windsor pattern was used on close to 20 different engines over the years, V8's, V6's, and I6's
But the Vulcan V6 and Duratec V6 do not share a common pattern with each other
Transmission model does not denote what it will bolt to, just tells you its internal structure or version
