Good idea. Thanks. I'm going to see if someone local can clean the heads for me also. If not then I will try to find long ass bendable nylon brushesYes, some kind of coolant additive, "stop leak" type product would be likely
Heater core and radiator might be blocked up
I would pull the water pump and flush the block
It definitely leaves some nasty stuff in there.Bars leak is such awesome stuff
So far my heads actually look to be in good shape. The pistons didn't have excessive carbon for the miles. I've been using the scotch-Brite green pads to clean the gasket surface's and it's looking good.I noticed you're in so cal... Have you tried cylinder head exchange in San Fernando? They would be a good place to start. That's what I did with my 2.9. two fresh heads with cleaned up valves. Shouldn't cost more than 400-500.
They are all a temp fix to unload a dying car on someone for car salesmen that are crooks. I have seen it many times. A reputible car dealer I do side work for bought a mint 4runner and made it 100 miles before it started overheating. Pulled the heads and basically same kind of crap was on the inside. All that stop leak stuff is junk. Glad you are getting everything sorted out.Not done yet but, I've decided if I ever see someone pick up a can of stop leak, I'm going to knock the shit out of their hand and give them a one hour, unwanted, tutorial on the dangers of giving your car drugs.
