- Mar 23, 2011
- Bridgeport, IL 62417
Swapping in DJM drop beams on my 93 and having a hell of a time getting the old axle out on the drivers side. Everything was going smooth until the spindle wouldn't pop out. I had to cut the end off the lower to finally get it to let go of the ball joint shaft. Removing the coil spring went normal but I can't get the bolt out to remove the axle from the radius arm. Any Ideas?
